logging Barometer reading
Postby GraemeD » Wed May 30, 2012 1:28 pm
noob question here,
How do I graph "baro"? I have a seperate baro sensor and I would like to be able to see it, as I live in Colorado and can gain/loos lots of altitude in a single drive.
'94 Miata ; 2001 VVT engine; DIYPnP, 3.3.B13; sequential injection Board; PWM IAC converter Board; VVTuner; 99-00 crank & cam sensors; sequential Toyota COP ignition; LC-1 wide band O2; Square Top manifold; RB header; Custom CAI.
GraemeD
Re: logging Barometer reading
Postby LT401Vette » Wed May 30, 2012 1:32 pm
It will likely take a custom ini with TunerStudio.
What firmware are you using?
Postby GraemeD » Wed May 30, 2012 1:40 pm
MSextra2 3.2.2 beta
2012-05-30_10.30.37.msq
(83.4 KiB) Downloaded 25 times
GraemeD
Postby LT401Vette » Wed May 30, 2012 1:48 pm
So if you just want to data log the barometer value that is displayed on the gauge, you need to add this to a custom.ini file:
Code: Select all
[Datalog]
   ;       Channel          Label          Type    Format
   entry = barometer,      "Barometer",         float,  "%.1f"
I did it in the attached.
So now place this attached file in the dir:
[YourTunerStudioProjectDir]/projectCfg/
Make sure to rename it to custom.ini
custom_baro.ini
Rename to custom.ini for TS to find it.
(190 Bytes) Downloaded 28 times
Postby GraemeD » Wed May 30, 2012 2:08 pm
Thanks,
I appreciate all the help
Graeme
Golden, CO
GraemeD
Return to Megalogviewer
