Log editing works- but I can't load file into Virtual Dyno
Zaphod
Post by Zaphod »
Hi Phil,
yesterday I made a quiet huge log including a 4th gear 2000-7200 rpm run.
I can cut the file in MLV and save as a new modified file - but I can't get Virtual dyno to load the file. (
I get the following error message in Virtual dyno:#
E101: Not all columns needed for calculations found.
REQUIRED COLUMNS: Time, RPM, Throttle Position
If your log does not contain these, the developer does not need your log.
I can load the whole huge file though...
Any ideas what I am doing wrong?
fun is not a straight line
Sven
http://www.mx-5club-sachsen.de
http://miata.cardomain.com/id/svenmx5
NB-1998-1,6-Garrett T25 HGP Turbo Stage I
Zaphod
Re: Log editing works- but I can't load file into Virtual Dy
Post by Zaphod »
Bump?!
Sven
nuvolarossa
Post by nuvolarossa »
Maybe a bug in mlv, doing something wrong/changing the file format when shortening logs?
upload here the big log and the short one so phil can see if something is wrong...
Robert
MS3x 1.4.1 | TS 3.0.28
Zaphod
Post by Zaphod »
http://www.msextra.com/forums/download/ ... w&id=34614
Here is the shortened log - the originial one is 18MB...
Sven
Post by LT401Vette »
It looks like your log has a # for the 1st row, I'm guessing the apps parser doesn't like that.
I can get rid of that.
Zaphod
Post by Zaphod »
O.K. thanks - will it be in an update?
Edit: Nevermind - I just removed the first row in Excel and it works! Thanks!
Sven
