I'm surprised I didn't notice this before, or maybe I'm missing a setting to display it right, but is there a way to have the y-axis for the top table set to one thing (Fuel - Load) and the bottom table set to a different y-axis (Spark - MAP)?
With the elevation changes I cover, I found fuel works best set to %Baro and spark to Speed Density (to automatically pull timing in denser air). This last weekend I was freaking out when the datalog reported Spark Advance as one number and the table on the right suggested a different number! Once I switched the y-axis back to MAP the numbers matched up, and then I looked for a way to set the two tables to have different y-axis units, but did not come up with an option.
Thoughts?
Different y-axis settings.
"Hey, at least the Skylark proves that even a messy hack can patch together a reliable EFI system. I can't think of a time the MegaSquirt has left me stranded since installation ~100,000 miles ago."
Drag Week 2011, 2012 & 2015. - BB N/A - 1977 Skylark w/Buick 455 EFI and TKO-600!
Re: Different y-axis settings.
There is the global Y-Axis field setting from the main menu, but you can also add a Y-Axis Override for a specific table.
Right click on the Y Axis of the table you want to change. Select Set Y Axis over-ride.
Did not know about the right click override, cool! Worked like a champ. Thanks again!
well its always good to have a read through recent posts i was about to start a topic asking the same thing, cheers just the info i was after.
