Data logging port status questions
jeffmarsh750
Post by jeffmarsh750 »
Was wondering the how to tell what the proper way to determine the calculated field for a port. Such as launch in, NOS activation in. Trying to figure out if these channels are effecting the timers after launch, as the timers for boost and NOS keep re-starting.
Thanks, Jeff
Fastest MS powered vehicle on the planet ! 6.60@208mph
Re: Data logging port status questions
Take a look at this temporary document:
http://www.msextra.com/doc/pdf/Megasqui ... Fields.pdf
It will be incorporated into a larger manual later.
jeffmarsh750
Do you have a page of the math channels to read each individual port ?
Thanks, Jeff
Post by racingmini_mtl »
I don't know if there is a document that gives the math but each port in the document linked (PORTA, PORTB, ...) is logged as a 0-255 decimal value. You need to convert that to binary and you will get an 8-bit value with each bit corresponding to what is in the document; a 1 means that the port is on and a 0 means it's off. If you don't know how, you can likely find on Google how to convert a decimal value to binary.
For example if PORTA is 129 then you have PORTA7 and PORTA0 that are on because 129 is 10000001 in binary. It's also 128 + 1 which you can relate to what in the document. Any number between 0 and 255 can be decomposed into a sum using the numbers 128, 64, 32, 16, 8, 4, 2 and 1. If you use one of those values in your sum then that port is on.
JAM
Post by JAM »
This is a great document, thanks for compiling this- after looking at my log it all seems to make sense now
one question; (or maybe a typo?)
from the doc;
portt is PTP (is this portp ?)
portt is PTT
The document mentioned above is now superceded and incorporated into the Megasquirt-3 TunerStudio reference manual. Yes that was a typo.
To pick out a single bit in one of those fields, in the registered Megalogviewer, you can use a formula such as
Field name: PT5
Calc: [portt] & 32
