I have a registered version and after an update to the latest version MLV will not start .It only displays the small Megalogviewer splash screen that disapperas in a second or two and then nothhing happens. I also installed the latest Java software (automatic update).
Now I reinstalled the old 3.4 MLV and it works. Any idea what could be wrong?
Computer is an Intel I5 Win7 machine.
Problem with latest Megalogviewer, does not run
Re: Problem with latest Megalogviewer, does not run
Did you install it from an installer or auto update?
Auto update installed the latest update. Should I go with the installer?
My best guess is that auto update didn't complete properly.
Yes that would be the best bet.Should I go with the installer?
Did you get it to work? I'm having the same problem using the installer.mega_user wrote:Auto update installed the latest update. Should I go with the installer?
