I cannot seem to get the VE analyzer to work. I logged everything possible in Tuner Studio and the VE generator is stating RPM, EGO cor1, AFR, VE Table1 and CLT are missing. I'm not certain where the software is looking for these values as each is selected in the playback as well.
Attached is a short sample log file
Suggestions?
VE Analyzer errors
VE Analyzer errors
1988 Mustang, 357W Clevor, 12.5:1 pistons, 2bbl Cleveland heads, Street Boss intake converted to EFI, 30lb/hr injectors (Red Tops), MS3.57 Extra, Full Sequential Injection, 190L/hr pump, TFI, MSD 6AL, T5 transmission.
Re: VE Analyzer errors
Everything looks fine there..
Check under the menu:
Options --> Field Naming (Log ECU)
That should be on Auto Detect
Thanks Phil for pointing me in the right direction!
VE1 table Analyzer now works!
Erik
Erik
