History trace filter
Postby dll67 » Sun Apr 16, 2017 10:02 pm
Often times the history trace covers the values in a cell. Is there a way to add a filter to quickly turn the trace off and on?
MS3X & IOx on 540 ci BBC w/325cc intake runners, 2100CFM TB, 72LB Inj, d585 coils, 60-2 wheel w/cam sensor Muncie 4 speed with 10 tooth VSS, Tilton 7.25" 2 disk cerametalic clutch on Tilton 8.5LB flywheel, Frd 9" detroit locker and disk brakes all around in a 67 RS camaro
dll67
Re: History trace filter
Postby LT401Vette » Mon Apr 17, 2017 7:45 am
Currently you can only change the length with the right click menu, there is no toggle.
Interesting suggestion though.
Postby 2swe » Mon Apr 17, 2017 9:09 am
How can I permanently change the history trace lenght ? every time I launch MLV it starts with 40 records history trace lenght..
2swe
Postby Brian H EFI » Mon Apr 17, 2017 10:09 am
Are you running MLV on Windows ? If you are and you edit the trace length it is automatically saved for you, however if you have multiple instances of MegaLogViewer open and do not close the instance that you had edited the trace length in last it will not get saved.
Brian H EFI
Postby dll67 » Mon Apr 17, 2017 11:12 am
dll67 wrote:Often times the history trace covers the values in a cell. Is there a way to add a filter to quickly turn the trace off and on?
What about some way to bring a clicked on cell forward through the trace? I saw mlvhd do that once when (I think right clicked) and drug the cursor through several cells .. Probably some little display glitch but got me thinking
dll67
Postby 2swe » Mon Apr 17, 2017 12:07 pm
Brian H EFI wrote:Are you running MLV on Windows ? If you are and you edit the trace length it is automatically saved for you, however if you have multiple instances of MegaLogViewer open and do not close the instance that you had edited the trace length in last it will not get saved.
yes, I'm running MLV on Win10, one instance only, and every time I launch MLV, I must edit the trace lenght manually..
sorry for hijacking this thread :)
2swe
Postby Brian H EFI » Mon Apr 17, 2017 12:12 pm
2swe wrote:yes, I'm running MLV on Win10, one instance only, and every time I launch MLV, I must edit the trace lenght manually..
Please send an email to support@efianalytics.com with reference to this post and I will look into why the trace length is not saving for you. Also what version of MegaLogViewer are you using is it HD or MS!
Brian H EFI
Return to Megalogviewer
