HP from a shadow dash log
Postby solo318 » Tue May 09, 2017 6:11 pm
I'm confused. When I select Hp from the drop down menu, then fill in the fields for hp and reload the log. Should I have a selectable field from the graph drop down menus? I've tried this multiple times and no luck getting to select a parameter. I have speed in the log, so I should be able to calculate hp correct? Where should I have to enter gear ratio and tire size etc? I havn't found a place in MLV or shadow dash to input these items. I've tried to upload a log file, but they are all too big.
As always, Thanks, Steve
Will race for food, or water, or for just the heck of it. I might even race for cash.
solo318
Re: HP from a shadow dash log
Postby solo318 » Tue May 09, 2017 6:55 pm
When I try to input wheels size etc in ts ultra, all of the fields are greyed out when I select userspeedmph. After blowing a wastegate diaphragm at the dyno, I'm trying to finish this thing up on the road.
solo318
Postby LT401Vette » Thu May 11, 2017 11:52 am
If all the fields required to create the HP field aren't available, it won't show up.
Is it the "HP" field or the "VSS HP" field not showing up?
HP should only require RPM and TP
Postby solo318 » Thu May 11, 2017 12:34 pm
For sure the HP. I can select ut from the drop down, fill in the required data, but it doesn't show as a field to select in the logs.
There were others as well, but I would have to go back and play with it some more to remember which ones.
solo318
Postby LT401Vette » Thu May 11, 2017 2:59 pm
If it isn't showing up, my best guess is that it isn't mapping one of those fields correctly.
I really need to see a short log to know for sure.
Postby solo318 » Sat May 13, 2017 2:01 pm
I have some logs at shadowlogger.com can you download them on your end? They are too large to attach here.
solo318
Return to Megalogviewer
