Logging EDIS PIP input and SAW output.
107merc
Post by 107merc »
Can I do this using calculated fields?? Couldn't find anything in search.
A setup formula would be much appreciated as this is a whole new world for me.
Thanks.
Re: Logging EDIS PIP input and SAW output.
Datalogging isn't fast enough.
107merc
Post by 107merc »
Thanks.
You can record these in an engine log, although the resolution may still be a bit coarse even there and you won't record much else.
DaveEFI
Post by DaveEFI »
107merc wrote:Can I do this using calculated fields?? Couldn't find anything in search.
Thanks.
Beauty of EDIS is there's no need to. If it sparks standalone, it is likely working just fine. If you connect to MS and TS shows the correct engine RPM, PIP is OK. If it doesn't, check you have the tach input on MS configured correctly. If the sparks follow the MS advance curve SAW is OK. (Best use a timing light to confirm the spark is happening where it should)
