(MLV 4.2.02)
Noticed a bug in MLV that it will start showing values with 3 decimal digits (x.000), instead of 1 (x.0), when there's a marker present in the log-file.
Before the marker, values are shown with 1 decimal.
After the marker, values are suddenly shown with 3 decimals.
Going back in the log to 'before the marker', MLV still keeps showing 3 decimals on all values.
MLV bug: MLV shows 3 decimals after log-marker
- Attachments
- screenpic1.jpg (17.34 KiB) Viewed 417 times
- screenpic2.jpg (17.02 KiB) Viewed 417 times
Re: MLV bug: MLV shows 3 decimals after log-marker
Can you post the log you are seeing this with?
Ok, noticed a different behaviour too;
- in the first log (2017-10-14_18.40.36), only Spark advance and RPM values get 3 decimals after the marker.
The other values kPa, CLT and BattV for instance stay correct at 1 decimal.
In the other log, all values get 3 decimals after the marker (at least, the yellow line in the log, is when I cycled the ignition key off and on, for when I got in/out of the car).
- Attachments
- 2017-10-14_18.40.36.msl.zip
- (174.91 KiB) Downloaded 25 times
- 2017-10-15_19.13.22.msl.zip
- (244.44 KiB) Downloaded 28 times
I think I've narrowed it down to "Time Gap: Calculated Record".
In a log, once you scroll across that area, the 3 decimals appear and don't go away anymore in any other part of the log.
