My MegaLogViewer HD 4.2 .06 has stopped displaying data in the histogram cells when I load more than two logs. It will show or play the data track if I click on the log display below, but no histogram data or color. The scatter plots are populated just fine with multiple logs loaded. HD used to load 5 or 6 logs and display histograms, now it balks at more than 1 and I have to close the program to get it back to displaying even one file.
I'm missing something, is there a limit on size or number of logs you can analyze?
Histogram not displaying data with multiple logs
Lotus Esprit w/MS3x, COP, Sequential, GM TB&IAC. Hall sensor on 36-2 crank,1 pin VR cam. MapDaddy, AEM X WBO2, Clock&Knock boards.
Subaru WRX hybrid w/MS3PNPPro SW0205, STi cams, VF39 turbo, 830cc injectors, VW boost solenoid.
MS3 1.5.1
TS v3.0.28
MS3 1.5.1
TS v3.0.28
Re: Histogram not displaying data with multiple logs
What size logs are you loading?
Nothings changed there for a while, The limit is really just the amount of memory allocated to it.
The histogram itself doesn't know anything about the number of logs loaded to the data set.
I actually had the same problem a few days ago. I also couldn't select RPM on the X-axis. Everything worked fine again after I reinstalled it.
My project: Link
