Is there a way to get MLV to generate just a VE table and not a complete MSQ? An MSQ burn takes much longer and can cause odd output behavior during a burn. I try to limit how often I burn a complete MSQ.
I really like how it works. It is an excellent tool to use.
Keith
VE table generation only?
I'm with you Keith, I was originaly just going to load vex files. But the with the advantages of having the whole msq tied together and I really don't like the makeup of vex files, so I did msq's first.
Tis does create the problem you describe, where you have to burn it all even if you were just using MLV as a table editor. Also, MegaTunix people are out of luck. I went to add vex support a while back, but decided to just make MLV burn the tables itself, so that effort is under way . However, my day job has gotten in the way and slowed progress.
Vex could go in a lot faster, so I should probably switch and through that in quick as it could be a few months before it is ready to read/write directly.
It really needs to have a core config loaded, like an msq, but then could add an import/export vex directly on the table it self.
Keith,
If you do an auto update, 2.60 supports VEX export. Click either the button above any table or right click.
