When I try to open the logfile this message comes up:
It was a rather large datalog that I was trying to open. I was probably logging for over an hour. There was some really good stuff in that log though that I wanted to look at.
It says to "start application with memory parameters", but I'm not sure what exactly that means. (i'm not much of a java programmer)
Anyone seen this before, or know what in means?
Java error when loading large .xls file
~Dudeck
Actually that is not a Java error. I throw that on purpose just before you are about to get an Error. ou pretty much need to do what it says, or:
Download StartForBigFiles.zip from:
http://www.ideasandsolutions.biz/MegaLo ... Utilities/
take the bat file in side, copy it to your install dir. Usually c:\Program Files\Megasquirt\MegaLogViewer
Then double click it to start. Then you shouldn't get a memory error.
I have considered putting in a 2nd executable with these parameters, or more memory yet. By default I leave it using as little memory as possible for the old tuner laptops.
Now you have me thinking..
MLV already checks your processor performance, you can see your "Processor Score" by looking in the "Help -> about" dialog.
I am thinking I should change the startup command based on that score. That score is really based on processor more than memory, but I think it is probably safe to assume that if you have a ~1.5 GHz+ procressor, you probably have at least 512Mb + memory.
My work laptop gets a Processor score of about 30,000 with a 1.6 GHz and 2 Gb RAM
My home desktop gets 160,000 with a Core Duo 6300 @ 2.27 GHz and 2 Gb Ram
So the startup command in the batch file would be fine and let you load files over an hour easy enough. Heck by doubling the parameters in the batch I have loaded files 3-4 hours long.
In the end that is really sort of a bandaid. I really need to make MLV not dependent on all data in memory. It just hasn't presented enough trouble.
