Mark the Log
Mark the Log
This is a question that spreads across both TS and MVL. Is there a way to be able to 'mark' the log if needed. What I mean is, say you are driving along and the car surges. Is it possible to do something like, for example, hit the space bar on the laptop and have that action visible as a mark when viewing the log in MLV. It would be handy for being able to study the point in a log where something odd happened when viewing the log later.
Thanks,
Jim
Thanks,
Jim
Re: Mark the Log
Yep.. Do thatIs it possible to do something like, for example, hit the space bar
hitting the space bar will put a mark in the log that MLV will display as a vertical red line in the graph and status bar.
Re: Mark the Log
Thanks Phil! It just never dawned on me to try it!
Jim
Jim
Re: Mark the Log
To bump an old thread ...
Is there a way to add marks to the datalog when viewing in megalogviewer. For instance when you find an abnormality and want to get back to it quickly?
MS3PU/IOx/CAN-EGT/DBWx2 540ci BBC 325cc int runners (2)innovate LC2 wbo2's, Hilborn ITB injector cnvrtd to EFI, 55LB Inj, d585 coil near plg, 60-2 trg whl & cam ph snsr, Muncie 4spd w/10T VSS, Tilton 7.25" cerametalic cltch 8.5LB flywhl
Re: Mark the Log
Currently no, but that does sound like a good feature, we will look into adding that for a future release!
- Running MSx/Extra
Re: Mark the Log
And to bump an old thread for another time , I find that when driving and I want to mark my logging , hitting the space bar does mark the log but it also makes the car stumble ???
Anyone ?
John
Anyone ?
John
Re: Mark the Log
About the only way I can think of that could happen is if it is an MS1 or MS2 and something has focus that causes a burn to be triggered.john.p.clegg wrote:And to bump an old thread for another time , I find that when driving and I want to mark my logging , hitting the space bar does mark the log but it also makes the car stumble ???
Anyone ?
John
- Running MSx/Extra
Re: Mark the Log
Ms1.v3 029y4...
Yes,it does feel like a burn to Controller...
John
John
