Hi guys,
I'm kind of frustrated with this right now so I figured I'd ask here before I get too annoyed.
I think this started happening since changing over to the Beta versions of Tunerstudio, but haven't tried to replicate the issue with regular versions. Whenever I take logs now, I can't open them up with Megalog viewer. I get an error "Log file contains no data or is not recognized. If this is an ADCII type log, check File Delimiter."
Works just fine with older logs.
Any ideas? Am I just retarded?
Here's a log.
Logs from Tunerstudio quit working in Megalog Viewer
Re: Logs from Tunerstudio quit working in Megalog Viewer
The issue was with TS. It should be fixed if you upgrade to the latest beta.
1993 Chevrolet Cavalier Z24
MS3 v3.57+MS3X
MS3 v3.57+MS3X
Thank you. Will download the update now.
This is happening to me too.
Im using TS Beta V2.6.14
What version MegaLogViewer are you using?
The Logs Generated by TunerStudio started containing units way back and well if you have a MegaLogViewer that is very old it won't know what to do with them.
MLV V4.0.04LT401Vette wrote:What version MegaLogViewer are you using?
All log files are 3kb.
It sounds like your logs are empty.All log files are 3kb.
So it does does not sound like a MegaLogViewer issue and certainly does not seem related to this 2 year old post you tagged on to.
Please start a new Thread in the appropriate forum with information to help understand what you have and what the issue is.
