Custom Field, distance traveled
I searched and found a few post and got this formula [DistanceFt-1] >= 0 ? [DistanceFt-1]+(5280*([MPH]/3600)*([Time]-[Time-1])) : 0 and I named it Distance. I tried entering that into the custom field inputs and I get a please check your syntax error.
Im new to this, and just copy and pasted. Is that the correct formula?
Re: Custom Field, distance traveled
There is field for distance traveled under:
Calculated Fields --> Optional Fields
Called TripFeet
That should do what you are looking to do. For the proper syntax, you can find the syntax for that in the MegaLogViewer.properties file in the MegaLogViewer install dir.
Called TripFeet
Im on the latest MLV update and dont see the tripfeet log field. I found ftsec is all.
Im just trying to figure 1/4 mile distance. I made a really good pull where I got to 120mph in 10.3 seconds and want to see how short I am from a full 1/4 mile to judge rpm increase or a tire change.
It's there, but on a smaller screen it is too far down the list and off the screen
I'm on the road so using my little laptop and suffered that trouble.
It is over time to put in a dialog to manage the optional fields. There are too many for the menus.
Anyway, here is the entry from the MegaLogViewer.properties, this gives the working syntax:
There is also a TripMiles in there too.
Code: Select all
APPEND_FIELD_TripFeet = [TripFeet-1] >= 0 ? [TripFeet-1]+(5280*([MPH]/3600)*([Time]-[Time-1])) : 0
Thanks Phil, I use a 15 inch laptop in the car and I count 7 fields using the down arrow I cant view before it returns to the top of the list. I wonder if changing the computers font size will rescal that? If not, when the laptop gets internet at home Ill add the field manually or use the 17 inch laptop the house uses.
I was able to put my laptop in Portrait mode and get the tripfeet and tripmile enabled. I reopened the log and the fields are not present, so I took a new datalog really quick and the fields are still not in the drop in the drop menus. Any ideas?
What field are you using for vehicle speed. They would be looking for a MPH field like gets logged by TS or Shadow Dash with GPS.
I'm logging VSS1 and VSS2. I can post my data log and Msq in a bit.
Heres the logs and tune, I can add other fields in the list and they pop up, just not the tripfeet or trip mile.
If using VSS1, create a custom field using the above formula only change MPH to VSS1 and TripFeet to what ever name you give the field.
Phil it seems I can always mess things up! Yesterday I tried inputting the formula you posted and I got the syntax error again. That's when I switched to portrait mode and actually clicked on the field.
This morning I reloaded the formula you posted and changed it to VSS2 and called it distance, and am still getting the syntax error. Is there something else I need to click on?
Revisiting this. I was able to check the Trip Feet box in the optional fields, but its not showing up in the viewable field list. Other things that I add like MPH per gear are there, just not trip feet.
That entry is actually as it would be in the MegaLogViewer.properties file. To add it as a custom field named Distance through the UI, enter this:
Field Name: Distance
Formula:
[Distance-1] >= 0 ? [Distance-1]+(5280*([VSS2]/3600)*([Time]-[Time-1])) : 0
However, as that field references itself, you will need to enter it while a log is not loaded so it will pass validation. Otherwise it will fail as it is referencing a field that doesn't exist (it self)
So open MLV, add the above custom field, then open your log.
Formula:
That did it. All working now, Thanks Phil.
