Megalog Viewer Status Annunciators
In the bottom right of the screen, there are 8 annunciators beginning with CRANK:N. Is there a way for me to customize and add others, such as Closed Loop Idle:ON?
Re: Megalog Viewer Status Annunciators
No, there currently is not. That is on the todo list though.DNMakinson wrote:In the bottom right of the screen, there are 8 annunciators beginning with CRANK:N. Is there a way for me to customize and add others, such as Closed Loop Idle:ON?
Did this ever get added?
1990 Mustang: MS3Pro Gen 1, 306ci, 72mm turbo, 80lb inj, 36-1 + Cam Sync + D585 coils, World heads, TFS1 cam, GT40 intake, auto, Speed Density
1987 Mustang: MS2v3.57, direct coil control, MSD VR Dizzy, SBE, Weiand 174,190cc heads, F303 cam, TBI w/ (4) 160lb inj, GT500 MAF
Yes it did, quite some time back. Fields that are logged as binary types (On/Off, Active/Inactive, High/Low, etc) are displayed 1st in the lower readouts and colored green when the state is true.
I don't think any of the ini files have been updated to log in that format though.
If you add any binary type fields in TunerStudio's Custom custome Channel Editor or in a custom.ini they will show up though.
