Any Water Injection active logging indicators?
T3Bunny
Post by T3Bunny »
So got my WI back online and hunting for data as I am not hearing the pump itself running...
I am trying to see when and where the WI system is active? I was surprised that I could not find anything in the gauges section below, or any option to see the status of the WI system.
Sure, I have a good idea from my settings where it "should" be activating, but not seeing anything in the logs to quantify that it is. The data I am seeing, indicates something else is going on...
I have Inj2 bank on mainboard setup for my WI valve output. I would assume that PW2, or duty cycle 2 would be my indicator here.... I have WI set to activate above 70% throttle (amongst other conditions). But I am seeing it coming on at only 31% throttle. Also, it shows PW1 the same, and I have that disabled.
System in question is an MS3 on 1.3a9 with a MS3X running my injectors.
1977 Rabbit (retired)
1991 Cabriolet (retired)
T3Bunny
Re: Any Water Injection active logging indicators?
Post by T3Bunny »
Well been trying for a few days now to up-load the .msq to go along with the above datalog... Every time I do, I get "The Page can't be displayed" error. Thinking perhaps I had too many attachments, I deleted a bunch. No luck.
Whatever the case, there seems to be an issue. And things are pointing towards it being a code issue too. Monitoring PW2 is showing a pw oddly shaped like the injector PW. But enough of that, that is a thread for the development section.
For this post, I really need a way to either look at the WI solenoid output PW, and or see a WI active indicator. Can anyone verify that when the WI solenoid is set to INJ2, I should see that output as PW2?
franksidebike
Post by franksidebike »
Hi
In TS Gauge go to Water Duty Gauge!
For Datalogging/SD Card Logging you must change:
In the project Cfg>mainController .ini this red change's
[Datalog]
; Channel Label Type Format
entry = time, "Time", float, "%.3f"
entry = seconds, "SecL", int, "%d"
entry = rpm, "RPM", int, "%d"
entry = map, "MAP", float, "%.1f"
entry = boostpsig, "Boost psi", float, "%.1f"
entry = throttle, "TPS", float, "%.1f"
entry = tpsADC, "TPSADC", int, "%d" ; for debug
entry = water_duty, "Water Duty", float, "%.1f"
Frank
T3Bunny
Post by T3Bunny »
THANK YOU!!! That is exactly what I needed!
