I don't know if this has come up before but I have just started using ITB mode for fuel while keeping Alpha-N for timing. Megalog viewer appears to be using ITB mode to show highlighted cells in both the fuel and advance tables. The logged advance doesn't match the highlighted one.
When using Alpha-N for both fuel and advance the correct cells were highlighted.
I am using 3.4.04 on Fedora Core 20 with MSExtra 3.2.5
ITB mode using Alpha-N timing
Re: ITB mode using Alpta-N timing
d*** typo!!!
If you right click on the Y Axis, you can set a Y-Axis over-ride field to track by.
Re: ITB mode using Alpha-N timing
Too easy!! Thanks!!
