new and puzzling problem
So over the last 2 days I was testing the car at the track and took several logs using shadowdash some and tuner studio some as well. All of these logs display just fine in MLV with one exception. The follow dot does not show up on the maps on the tuning console while playing the log or stepping through it. I don't know what I might have down but it was working before I changed the default axis from MAF to MAP on the spark and AFR tables in MLV. It then said Id have to reload the tune in MLV which I did and since then its ben busted. Any advice would be great .
Ricky-
MS3&MS3X v.3.0 PCB
LS3/LSA card MAF sensor
97 Mazda MX5
MS3 2002 vvt motor
.60 trim T4 Turbo at 15 PSI
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
Re: new and puzzling problem
figured out the problem. When I put it in y axis override and typed in to use map ....i didnt pay attention to case. It took the change with no warnings about case or syntax but would not function on either table . I went in and changed to upper case MAP and it fixed the issue. Just to see if it was repeatable I went back in and put lower case map in and sure enough it busted it again.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
