Can someone have a look at this log and give me a second set of eyes on it.
Running MLV 3.4.04 on an MS2 V3 V3.2.5
When I run VE analyzer I can't get it to filter the Over Run Events and there are a few. I don't even see status3 triggering? Any ideas on this??
Over Run not filtering?
Re: Over Run not filtering?
My ghetto work around filter for now
[PW]<1.5||[AFR]>20||[TP]<5
There is nothing wrong with the work around. I have used [PW] == 0 also.
You may also want to add some delay too, so it ignores a few records after the fuel comes back on:
([PW] == 0 && [PW-1] == 0 && [PW-2] == 0 )
Thanks Phil! Since I didn't know how to delay, that's why the pw number isn't zero
Is this a problem then and not just me or my machine?
Hmm, If you check and uncheck the "Disable Overrun Filter" under specialized Options, do you get the same results?
In all this time I have never honestly seen that menu... Overlooked it I guess. It does make a difference when I use it or not. It seems to still try and adjust to much on the overrun area.
Is this also tied into the lambda delay table?
