Anybody else having trouble displaying the "AFR Target 1" in a log file? Mine constantly stays at 14 regardless of target table AFR.
Thanks!
MLV 3.4.03
AFR Target 1
Re: AFR Target 1
What firmware? Can you post an msq?
MLV just reports what the firmware says it was targeting, it does not generate the AFR target value.
Re: AFR Target 1
Using firmware 3.2.5. I thought it pulled it from firmware. MLV is tuning to the target, just not displaying on the histogram correctly.
Re: AFR Target 1
For VE Analyze, MLV does do lookups on the AFR table instead of what is reported back, but for what is displayed as a log value, it uses what is reported by the MegaSquirt.
Looking at your msq, your EGO Sensor Type is Disabled. that is likely why it is being displayed as a steady value.
Re: AFR Target 1
Ah hah.
Can I have it display the AFR table value by adding a field?
Re: AFR Target 1
There is not a table lookup function in MLV.
