Any way to log digital switched inputs
Would like to log digital switched input to see if it is re-activating the 2 step going down the track. Don't see it in the menu.
Fastest MS powered vehicle on the planet ! 6.60@208mph
Re: Any way to log digital switched inputs
Enable PORT_STATUS in your TunerStudio project properties, then you can log raw port values.
In Megalogviewer you need to add a calculated field to pick out the specific pin from the port.
e.g.
PT6 = [portt & 64]
e.g.
PT6 = [portt & 64]
Can this be done with the SD card log ? this is on a bike and can't carry the lap top along
Tank bag, tail bag, saddle bag, back pack?
Not at 200mph, this is a drag bike. The slowest it will go is 175 on a pass.
No laptops on the drag strip please !!
Yes, these fields can be added to the SDcard datalog set - once you have enabled them through project properties.
