I have both the current MLV and MLV HD (3.4.07) as of today. Both work normally with logs from MS. However, neither are working with logs from Torque. I even trimmed the log to just a few rows to see if that helped and I get the same error.
The error is "Entire log file not loaded: Log file not found".....
I attached a screenshot of the error and the small test log that is failing.
I uninstalled both MLV programs, deleted their folders in Program Files and Program Files(x86) and cleaned the registry and reinstalled MLV HD and get the same error. I also adjusted the options for to use CSV and Torque.
Thanks for your help.
MLV error loading file
Re: MLV error loading file
Please work directly with support <at> efianlytics. com for non-megasquirt issues.
This forum is only for MegaSquirt discussions.
If you have a longer files, send that. That file only has a few records, which may be causing the trouble.
