Out of memory errors trying to load large log files
hardline
Post by hardline »
I am getting out of memory errors when trying to load large log files. Is there a setting that can be tweaked to allocate more memory to the java app?
Re: Out of memory errors trying to load large log files
Post by LT401Vette »
If you drop this StartForBigFiles.bat in your install dir and run it, it will allow it 2GB of memory.
http://www.efianalytics.com/MegaLogView ... Utilities/
How big a file is it?
How much RAM do you have on the PC?
hardline
Post by hardline »
The file is 250 MB or so. THe machine I do all my Megasquirt stuff on has 8GB of DDR3 Memory. I could up it to 16GB if needed.
hardline
Post by hardline »
This worked. Now I can look at a log file of my drive from St. Louis to Denver
kaya67
Post by kaya67 »
I've also gone and re-set the VE table size back to 16x16 in Tunerstudio and the values that show up in MLV are reflected in the new table. Haven't had a chance to try it in the car to see if the issues with running are resolved but now I've smoothed out the values so they are not jumping from 35 to 76 and back to half again between adjacent cells I'm thinking it might run a little better.
Pass your 199-01 exam on first attempt using Harvard University and other resources. We offer 100% success in SAP with up to date testking University of Wisconsin - Madison by experts. You can also find Youtube Good Luck.
