hi
please open attached log file, and see the strange values of the log,
i can evaluate nothing with this values.
the car runs fine, but the log file....
im using the Aten Rs232 cable, since i work with megasquirt, i always use this usb converter.
what happens to have a log file like this?
usb ports?
computer speed?
etc
Strange values on log files
Re: Strange values on log files
Yes the data in that log looks corrupt.
What is it from? Is it from a running engine or a Stim? What firmware? What did you use to data log?
its from a runing car, not stim.LT401Vette wrote:Yes the data in that log looks corrupt.
latest firmaware
my eepc asus, to data log, conected via rs232
I have no idea what that means.latest firmaware
What version of TS?
That log looks to be an edited log or it would have the firmware in the header.
Do you logs consistently look like this, or is this a one instance?
Is it only after export or editing the log?
Do your gauges read normal?
