jump to high point
jump to high point
Phil is there a way to jump to a max or mim on the garth? to view that point on the datalog with out having to guess where it is at?
Re: jump to high point
Search > RPM (for example) > Jump to Max: xxxx
1990 Nissan 240sx / SOHC KA-T / DIYPNP
BigLou240sx wrote:Search > RPM (for example) > Jump to Max: xxxx
Thank you!
