mlv indicators
mlv indicators
under the graph where it says crank:n ase:n warm:n run:y can those be changed out id like to see one for over run fuel cut if there is any way I have some afr lean spikes and I think its because of over run maybe not being setup correct
Re: mlv indicators
No, those are tied directly to the "Engine" field. More flexible indicators are on the todo list.
Re: mlv indicators
Seems that it could be useful for MLV to be more integrated with the TS project data?
Re: mlv indicators
Yes it would, for several other reason. It would then even be able to open MS3 SD logs directly and edit all tables.jsmcortina wrote:Seems that it could be useful for MLV to be more integrated with the TS project data?
But that integration needs to stay optional, it needs to be able to work stand alone without a project as well for basic log viewing.
Re: mlv indicators
Okay on the indicators! I don't know a thing about programming but could it be as easy as just putting a option for the standard type of MLV and then a project based version.. I'm assuming it needs to be that way for sharing msq and data logs. Also it's probably a ton of work.
