Estimating airflow in lb/min formula
Does anyone have a formula that will estimate airflow from rpm, map, iat, and baro? Trying to plot where my engine is in the turbo compressor efficiency map for it.
Re: Estimating airflow in lb/min formula
That will work going forward, but I'll have to play with that formula to see if i can get megalogviewer to display this with existing datalogs
There is a calculated field called Mass Air Flow.
That calculated MAF from fuel flow and your AFR. It takes injector size in lb/hr and displays MAF in grams/sec
Thought I'd give closure to this thread and show you my end results.
