Estimating airflow in lb/min formula
hardline
Post by hardline »
Does anyone have a formula that will estimate airflow from rpm, map, iat, and baro? Trying to plot where my engine is in the turbo compressor efficiency map for it.
nathaninwa
Re: Estimating airflow in lb/min formula
Post by nathaninwa »
hardline
Post by hardline »
That will work going forward, but I'll have to play with that formula to see if i can get megalogviewer to display this with existing datalogs
LT401Vette
Post by LT401Vette »
There is a calculated field called Mass Air Flow.
That calculated MAF from fuel flow and your AFR. It takes injector size in lb/hr and displays MAF in grams/sec
hardline
Post by hardline »
Thought I'd give closure to this thread and show you my end results.
