Playback speed nowhere near correct?
MWPau
Post by MWPau »
Hi all,
Log file playback speed is no where near what it should be.
100% speed is about 60% of real time, 200% is about 80% of real time, and 400% is about 150% real time.
Bug, or something else?
Logs are from MS3, 100 frames/sec.
Re: Playback speed nowhere near correct?
Post by LT401Vette »
I assume this is in MLV?
Can you post a log?
MWPau
Post by MWPau »
Yeah, MVL 3.4.03.
Attached.
Yes, I see what you mean.
It appears there is a sleep in the playback thread to preserve CPU utilization that would cause a problem to playback on logs with data rates over 50/s.
I will need to fix that.
