lamda delay on ve tuner for afr
what is meant by one record? on the lamda sensor delay bar! how do you tell if you measured on record distance
98 VW golf gti vr6 turbo 8:5:1 cr ported and polished full ferrea race valves train 276 cams custom short runner intake Borge 366 sx-e turbo forge wossner pistons, balanced rotating mass, limited slip 6 speed deka 750Lbs injectors on ms3pro completed AWD swap
Re: lamda delay on ve tuner for afr
In tuner studio go to Communications and see what data rate you are running. That will tell you how many reads per second you have selected. 15 reads per second means you get a record every 1/15th of a second or 66.6mS.
Cheers Luke
Cheers Luke
Thanks Luke, is there a way to see ms in the log so I can set my delay correctly or close?slow_hemi6 wrote:In tuner studio go to Communications and see what data rate you are running. That will tell you how many reads per second you have selected. 15 reads per second means you get a record every 1/15th of a second or 66.6mS.
Check the time bar or field. See how many ms from one record to the next.Thanks Luke, is there a way to see ms in the log so I can set my delay correctly or close?
Thanks phil, did I every mention how muck I hated math in shcool! I geuss this is payback!LT401Vette wrote:Check the time bar or field. See how many ms from one record to the next.Thanks Luke, is there a way to see ms in the log so I can set my delay correctly or close?
