lamda delay on ve tuner for afr
nathanhardy
Post by nathanhardy »
what is meant by one record? on the lamda sensor delay bar! how do you tell if you measured on record distance
slow_hemi6
Re: lamda delay on ve tuner for afr
Post by slow_hemi6 »
In tuner studio go to Communications and see what data rate you are running. That will tell you how many reads per second you have selected. 15 reads per second means you get a record every 1/15th of a second or 66.6mS.
nathanhardy
slow_hemi6 wrote:In tuner studio go to Communications and see what data rate you are running. That will tell you how many reads per second you have selected. 15 reads per second means you get a record every 1/15th of a second or 66.6mS.
Thanks Luke, is there a way to see ms in the log so I can set my delay correctly or close?
LT401Vette
Post by LT401Vette »
Check the time bar or field. See how many ms from one record to the next.
nathanhardy
Thanks phil, did I every mention how muck I hated math in shcool! I geuss this is payback! :roll:
