Hi
I use MegaLogViewer to show the logs made by another sw that is not in the Option->Field Naming Menu.
I observed that in C:\Programs\EFIAnalytics\MegaLogViewerHD there is the folder "FieldMaps" that contains the properties of many formats (like Torque)
Now, to use at 100% the power of the sw (I.E. Calculated Fields), the base Fields must be loaded and recognized by the program.
How I can do this? Can I create my .properties file?
The Header of my log is:
Time,COOLANT TEMP (C),INTAKE AIR TMP (C),IGN TIMING (BTDC),CAL/LD VALUE (%),NB-O2 SEN 2-B1 (V),NB-O2 SEN 2-B2 (V),A/F CORR-B1 (%),A/F CORR-B2 (%),ENGINE RPM (rpm),MAS A/F -B1 (V),MAS A/F -B2 (V),INJ PULSE-B1 (ms),INJ PULSE-B2 (ms),B-FUEL SCHDL (ms),MAF GM/S (gm/s),ACCEL PED POS 1 (V-Accel),THROTTLE POS 1 (V-Throttle),VEHICLE SPEED (mph),A/F WB-B1 (V),AFR WB-B1 (AFR),A/F WB-B2 (V),AFR WB-B2 (AFR)
The first row is:
46,84.0,20,56,16,0.68,0.32,96.0,94.0,2188,1.42,1.45,2.3,2.3,3.0,11.04,1.02,0.75,36.2,1.260,12.96,0.745,11.75
File .propertis
Re: File .propertis
seeing this is non-MegaSquirt related, email support at efianalytics.com
