Is there any way to use a static center point instead of 50%?
I would like to compare my EGT channels to a static number instead of the average value
Datalog Field View
Re: Datalog Field View
Nope.
Let me see if I have the need straight.... You want to be able to set the horizontal dashed line to a specific value so you can see where the other EGT's are relative to one?
Can't you get the same effect by setting fixed limits?
For example, set lower limit at 500, upper at 1000, then the center line would always be at 750.
Eric Law
I remoted into my desktop and that looks like it's exactly what i was looking for.elaw wrote:Can't you get the same effect by setting fixed limits?
Thank you!
Phil, yes that's basically what i want to make it easier to trim other cylinders.
