Datalog Field View
Mario
Datalog Field View
Post by Mario »
Is there any way to use a static center point instead of 50%?
I would like to compare my EGT channels to a static number instead of the average value
1967 Beetle My test mule
The Dub Shop
Facebook
Megasquirt for life!
LT401Vette
Re: Datalog Field View
Post by LT401Vette »
Nope.
Let me see if I have the need straight.... You want to be able to set the horizontal dashed line to a specific value so you can see where the other EGT's are relative to one?
elaw
Post by elaw »
Can't you get the same effect by setting fixed limits?
For example, set lower limit at 500, upper at 1000, then the center line would always be at 750.
Eric Law
Mario
Post by Mario »
elaw wrote:Can't you get the same effect by setting fixed limits?
I remoted into my desktop and that looks like it's exactly what i was looking for.
Thank you!
Phil, yes that's basically what i want to make it easier to trim other cylinders.
The Dub Shop
Facebook
