mega log viewer log file issue from shadow dash
Not been on here for a while or drove my car much either.
Anyhow, I'm having problems with my log files from msdroid.
After they have uploaded to shadow tuner and i have down loaded them to my laptop I can't seem to open them.
I gives me a error of no data or is not recognised?
Sorry if this has been asked before.
1974 Range Rover Classic powered by a ls1 gen 3 5.7ltr coupled to a 4l80e ran with a compushift.
LS1 is ran using ms 2 extra
Newbie but learning all the time
Re: mega log viewer log file issue from msdroid
Can you post a log that won't open?
Here is one of the files that won't open.
That file has no data in it. So MLV won't be able to open it.
Do you know the reason for this.
Is it something in the settings from msdroid?
Erm.... ask the MSDroid developers?
Moving to that section.
Sorry its not msdroid its MS shadow dash,
I have enable automatic logging ticked
Start logging on connect ticked
Use FRD data logs ticked
Log acceerometer data ticked
Log GPS data ticked
Automatic log upload ticked
Log GPS data ticked
Well, that confused me for sure. I've edited the topic title.bluebob wrote:Sorry its not msdroid its MS shadow dash,
Re: mega log viewer log file issue from shadow dash
Thank you
Usually you use either Automatic Logging with a condition set, or Start Logging on Connect.
What condition is set?
Is there any particular readon for FRD logging to be checked? It is easier to go strait to msl.
How did this log get transformed from an FRD to an msl?
My mistake on the frd, its not checked.
After checking my other logs its only one that shows no data, so maybe a connection issue.
Since the update on shadow dash i have been having connection issues.
Or, if you are running an MS3, it looks like there is a problem with logging to an FRD. It doesn't read the full outpc as would be expected in an FRD.
MS2 extra Phil
Then that isn't it...
If that is the only one, it could have been created from a failed connection...
