Hey.
dyipnp whit latest firmware.
Cant understand what warm y/n is. is it when temp is under 70 c ? goes on off som times in log file.
My log is here.
Thanks Martin
Warm y
Re: Warm y
That indicator is driven by a bit in the Engine field to indicate that Warmup Enrichment is active.
Looking at your warmup Enrichment curve, it is set up somewhat odd. with the high point set to 114°C, but set to negative enrichment (98% and 97%) at points.
Also it looks like you are tripping Accel DE at WOT and Decel Enrichment is set for 75%, thus cutting fuel quite heavily. Either set DE back to 100% or raise the MAPdot threshold.
Re: Warm y
Thank you for your quick reply ;-)
The log whas on the dyno.an not as expected because accel de and cooldstart as you mentiod.
Can you have a look on my msq . i chance to tps only and adjusted cooldstart setting..are my settings good for a turbo car .
is it normal to only sellect tps on a boosted car ?
Martin ;-) sorry my english
