Hi, Is there a way to be able to view the Idle VE table in the tuning console?
I am having quite a bit of trouble completely sorting a stall issue that happens very sporadically when the Air con is activated. I am getting better at analysing what is going on through MLV, and the last data log I took shows the stall starting as Status 6 Idle VE activates. I'd like to be able to track what bins it is tracking through as the stall progresses.
Thanks, Arran
Idle VE table in MLV Tuning Console?
http://web.aanet.com.au/arran
Re: Idle VE table in MLV Tuning Console?
As MLV doesn't read the ini files, it does not add new tables on it's own. They need to explicitly added to MLV code.
So no, you can not currently. There is something in the works that will take care of this though.
Hi, thanks for that, much appreciated
