MLV and status 1 to 8 graphic display?
arran
Post by arran »
Feature request - Can the contents of the status registers be presented graphically in Megalogviewer?
Similar to Crank, ASE, warm up, run, .... at the bottom right of the console, it would add a lot of "ease of use" to the experience. I am currently trying to look at what is happening with Idle VE, Air Con, Fan and having to sit here with a calculator converting dec to bin to see what is happening with bit 5 or 6 is a lot harder that ideally it could be.
Thanks, Arran
http://web.aanet.com.au/arran
Re: MLV and status 1 to 8 graphic display?
Post by LT401Vette »
It is on the todo. Right now all you can do is create a calculated field that will display if the bit is on and off. That helps a great deal, but isn't what a stand alone indicator would be.
arran
Post by arran »
Thanks, ill keep an eye out for any updates. Also thanks for the tip on the calculated field.
Arran
shaodome
Post by shaodome »
any updates on this?
arran
Post by arran »
Based on what I read in the embedded help in MLV I put together this formula to display when idle ve is active:
[Status6]>15&&[Status6]<32||[Status6]>47&&[Status6]<64||[Status6]>79&&[Status6]<96||[Status6]>111&&[Status6]<128||[Status6]>144&&[Status6]<160||[Status6]>175&&[Status6]<192||[Status6]>207&&[Status6]<224||[Status6]>239&&[Status6]<=255
I can't see how to use a BITTEST function like I'm more familiar with in Assembler, but with a combination of AND and OR the status6 value can be tested to see if it is BETWEEN a number of values, indicating that bit 5 is active. Not very elegant
A single ampersand, like in C.
value & mask
e.g. [Status6] & 32
arran
Post by arran »
Thanks, a couple of handy custom fields I've just setup:
To display when Closed loop idle is active:
[Status2]&128
To display when Idle VE is active:
[Status6]&16
To display when Idle Advance is active
[Status6]&32
The '&&' results in a true/false 1 or 0 result but did NOT correctly track the Status bit. '&' results in a decimal value and correctly tracks the bit value
The && is a logical AND, so both sides of it need to be true (non-zero), then the output will be 1.0.
Where a single & is a bitwise AND, so the output will be the value after applying the mask.
Example:
64 && 32 = 1
32 && 32 = 1
(32+64) && 32 = 1
64 & 32 = 0
32 & 32 = 32
(32+64) & 32 = 32
You can use binary to make it look clearer:
0b00100000 & 0b00100000 = 32 (0b00100000)
The output is always in decimal, but the input can be Hex, Oct, decimal or binary.
Peter Florance
Post by Peter Florance »
Sorry for the hijack, but can I use bit wise & to mask the upper 4 bits of a value?
I want to log wheel speeds via CANbus, but they are first 12 bits and I need to throw away the 4 highest order bits.
Sent from my XT1080 using Tapatalk
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
Yes.
Mask it with 0x0fff
Not sure how MLV accepts the C-style 0x prefix for hex ??
That's 4095 in decimal.
i.e. [raw value] & 4095
Peter Florance
jsmcortina wrote:Yes.
Mask it with 0x0fff
Thanks!
Peter Florance
PF Tuning
MLV's Math parser is fine with the 0x prefix or 0b for binary 0b111111111111
Peter Florance
LT401Vette wrote:MLV's Math parser is fine with the 0x prefix or 0b for binary 0b111111111111
Very cool. Thanks
Peter Florance
PF Tuning
