my mac does not like the latest megalogviewer...
JoseMiguel
Post by JoseMiguel »
I just updated to the latest megalogviewer on my Mac (OS X Yosemite) and it wont run. No errors displayed.
The previous version was working correctly. The latest TunerStudio is working good.
Thanks for the help
LT401Vette
Re: my mac does not like the latest megalogviewer...
Post by LT401Vette »
I think I see the problem....
4.0x is compiled for JRE 1.7, OS X is forcing MLV to use JRE 1.6 on apps packaged as MLV.
If you download the Linux version and run it by double clicking the jar file, it will run under a current JRE.
Also I will put out a patch release compiled to 1.6 as there are currently not 1.7 API's needed.
LT401Vette
I have put a new update for OS X 4.00.04
It is compiled for 1.6.
You will need to uninstall the broken .app and reinstall, then the update should be good.
JoseMiguel
Sorry Phil... in the downloads page I still get 4.00.03
let me know, looking forward to test it as I greatly depend on this software
LT401Vette
Which one are you using?
The OS X installer is still 3.0.4, then it needs to autoupdate to 4.0.04
Or are you using the Linux version now? That should work fine if you have a 1.7+ JRE installed.
JoseMiguel
I cant open megalogviewer (so no autoupdate possible) so I went to your website to download the new version, but in the website there is still version 4.0.03
LT401Vette
Not the one for OS X, it is very old. version 3.04.
JoseMiguel
Im sorry, im probably missing something...
I already unistalled megalogviewer. Is there somewhere I can download the latest fixed version? Or should I download the linux version.
LT401Vette
There is no current installer for OS X, the one out on the download site it an older version (3.04), that will run fine, just be older. But if you install that back, it will then auto update to 4.0.04
If you download the 3.04 for OS X version from either:
http://www.tunerstudio.com/index.php/downloads
or
http://www.efianalytics.com/MegaLogViewer/download/
Then it will update to 4.0.04.
JoseMiguel
LT401Vette wrote:There is no current installer for OS X, the one out on the download site it an older version (3.04), that will run fine, just be older. But if you install that back, it will then auto update to 4.0.04
or
Now I get it... my bad!
Ill let you know how it ends up!
JoseMiguel
Phil, everything worked perfectly. Thanks for your help!
