I would like to change the dot size in the scatter plot, ist this possible?
I have short full throttle logs and would like to get a power curve. How many dots are set. Is it one per second, or just the datarate I set up? I Would like to have many many dots so I get a nice full throttle curve, otherwise it is very difficult to recognise the line.
Julian
MLV questions about scatter plot
Re: MLV questions about scatter plot
Yes the dots get bigger with the number of hits to it.
So if you have a higher data rate they will get bigger and cover things better.
It would be good to have a user setting to increase the dot size too.
