Engine Log Help
Mario
Engine Log Help
Post by Mario »
When I am looking at an engine log there is a Vertical red line at consistent intervals. What does this represent? Thanks!
1967 Beetle My test mule
The Dub Shop
Facebook
Megasquirt for life!
kjones6039
Re: Engine Log Help
Post by kjones6039 »
To the best of my recollection, those are time gaps........
It might help if you were to post the actual log!
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Mario
Re: Engine Log Help
Post by Mario »
It shows up as a Mark in the log file But I don't know how or why it is triggered, I can't find anything in the manual that references it either.
The Dub Shop
Facebook
john.p.clegg
Running MSx/Extra
Re: Engine Log Help
Post by john.p.clegg »
Hitting the space bar during logging gives the red line...
John
Mario
Re: Engine Log Help
Post by Mario »
Yes, this is the same type of Mark you would get hitting the space bar. but it is at very specific intervals. So my though is that this is when the ECU is starting the Sequential cycle over and the line is a representation.
Phil, can you confirm that for me?
The Dub Shop
Facebook
LT401Vette
Re: Engine Log Help
Post by LT401Vette »
Yes, the red lines are MARKs.
In a normal log there is a MARK if you hit the space bar or an event like going offline occurs.
With the high speed logs like the engine log, the data is not read in a steady streaming fashion like a normal data log. In this case The Firmware writes the raw data to a page of RAM, then when the page is full notifies TS that the page is ready to read. TS reads that page, then the firmware starts logging again.
So you will end up with chunks of data with pauses between them. To make it easier to see where these data gaps are, there is a MARK. So you can know that you shouldn't expect the data have proper continuity across the red line.
Mario
Re: Engine Log Help
Post by Mario »
Thank you for the clarification Phil, that is just what I was looking for!
The Dub Shop
Facebook
