Feature request : tuning console on scatter plot tab
I'd absolutely love to have acces to tuning console on scatter plot tab, (switching between scater plot and log viewer tabs sucks), does not matter if it was two tables bottom , or one table "floating" over scatter plot.
some kind of interconnection between table and scatter plot would be nice. I mean when I select one (or more) bins in table, it should highlight the area in scatter plot most affected by selected bin(s) and vice versa.
is it doable ?
1978 vw golf gti 16v itb cop full sequential MS2
1992 vw corrado 16v moonlight blue MS2
Re: Feature request : tuning console on scatter plot tab
I like this idea as I do tab back and forth for the same purposes.
It would also be helpful for folks that install megasquirt on a carb'd car but datalog the carb fueling before switching to injectors and can get at least an AFR map or sense of scale between idle, cruise and WOT. Particularly if they feel the drivability of their carb isn't terrible.
It sounds reasonable. Actually how I would probably expect it to be laid out would be to have the tab only cover the graph type and the have the tables be persistent on the line graph/scatter plots or Histograms. That is probably how it would be laid out if I had originally be expecting the different graph types.
