Hi, so I'm just starting to play with my ms1 on my 1.6 (na 93) mx5/Miata. the car has a solid dyne tune from last year, but its had a turbo upgrade and 3" exhaust added over the winter so id like to try and dial in the fuel map using VEAL.
my (perhaps daft) question is how do you set multiple target AFR's , as in, i want it to be around 14.7 afr in the light throttle and up to 100kpa ranges, then id like it to be looking for 11.5 after 100kpa up to 200kpa as it comes into the boost region of the map.
how is that set up? or have i got the wrong end of the stick???
any help gratefully received ….
newbie advice on VEAL
Re: newbie advice on VEAL
Both VEA in MLV and VEAL in TunerStudio target the AFR defined in the AFR target table.
