I really thought this was going to be easy! I want to mark log records when AFR Safety System is active. Based on other threads, the following looks right to me, but MLV is rejecting it. What have I done wrong?
Jeff
Custom field for AFR shutdown
Re: Custom field for AFR shutdown
With no log, I can't say for sure. But my 1st guess would be that you have the s in Status6 in lower case, In most firmware logs I know of it is upper case.
The OutputChannel is lower case, but the DataLog field is Upper.
I should have looked at my logs rather than searching the forum. Status6 is indeed capitalized.
Thanks!
Jeff
Thanks!
Jeff
