>4 Graphs is buggy
>4 Graphs is buggy
Hi Phil,
When enabling over 4 graphs, graphs 5,6,7,8,etc only have one item selection box, and when an item is displayed the graph color doesnt match.
Ie:
Ie:
Re: >4 Graphs is buggy
Argh, sorry, wrong forum!
Can someone please move this thread?
Yes, that is easily reproducible.
I will fix.
I will fix.
Was this meant to be fixed in 4.0.12?
It doesn't seem to be.
And a quick question/request instead of starting a new thread.
What is the status of support for 128 byte logs?
Nope not in 4.12. That is in the next release.
That will be in the betas for TS 3.0
For MS3 SD Logs?What is the status of support for 128 byte logs?
Okie dokie.
Im looking forward to the fix and especially the 128 byte log support.
Hey Phil,
I did the update today.
All looked good to begin with... then i removed an item from the 3rd graph, and all the colors went out of whack.
And....
Loading a quick view that doesnt use graphs >4 doesnt clear out the graphs >4.
Ie, if you have an item loaded into graph5, then use a quick view, the item on graph5 remains.
