Any way to compare two datalogs?
aw113sgte
Post by aw113sgte »
Right now when I make datalogs, I have to load all the data into excel and use it to make the graphs. Is there anyway to compare two separate datalogs within Megalog (full version)? Right now when I make datalogs, I have to load all the data into excel and use it to make the graphs. (I want to make a scatter plot of dutycycle vs rpm but show two datalogs on one graph) I feel like I must be missing the method of doing this as it seems like a pretty core need.
Re: Any way to compare two datalogs?
Post by LT401Vette »
File --> Compare To
The data in the Compare file is only on the main graph, not on the Scatter plots.
I could put a toggle to switch a scatter ploy from the main data to the compare data.
jacky4566
Post by jacky4566 »
Phil i'm bumping an older thread. Did you ever make this feature/button?
I want to compare two logs in scatter form.
X: RPM
Y: Ignition advance
Z: Acceleration in X direction.
No, there is still no compare in scatter plots.
