Hi all,
Phil, I have found an problem when I need to modify the "Hits" scale on the Z Axis to have a better colours distribution on the filled graph.
If I remove the tick from "Use Default" box and put my own numbers, simply nothing happens.
RPM and other fields seems to work as expected.
Is there an solution to this?
Thank you.
Cheers,
Fabio.
Scatter Plots: Hits Z Axis manual Scale problem
Yamaha V-Max V4 paired odd-fire 1200cc engine - ITB - COP
MS2/Extra Pre 3.4 beta 11
Sequential spark & fuel - ITB Algorithm
Re: Scatter Plots: Hits Z Axis manual Scale problem
For hits it wouldn't make a difference as Hits isn't actually a field... I'll have to look at putting handling in for that...
I don't know why the maximum value associated to Hits on the Z axis is quite off. I mean that while on the plot (filtered) I see values like 1902, the upper side of the Z axis (on the right of the screen) is only 187, so a wide range of Hits are painted with the same red color, making difficult to understand the situation.
Fabio
Thank you Phil.LT401Vette wrote:...I'll have to look at putting handling in for that...
Fabio
Hi Phil,
Is there a fix for this yet? I am in need of looking at data point frequency and it currently does not scale properly from what I can tell.
Thanks,
Matt
Thanks,
Matt
The scale is still linear. If you have many hits on 1 pixel it will skew the scale.
