Low Application Error - Mac
How do we fix this on a Mac?
Re: Low Application Error - Mac
By the way i'd like to add I don't recall having this problem on the previous version of MLV, but then I haven't been working with files this large for some time.
I am logging my entire drive home and yesterday it took an hour and a half.
Is that a Low Application Memory Error?
You could start it from a terminal using the MegaLogViewer.sh file.
That will start the JVM allowing up to 1 GB of Memory.
How would I do this?
Where is .sh file located? Any specific sequence of commands to run it with higher ram?
The location may be obvious... I just haven't touched it since I posted.
If you are using the Linux download, it will be in the same dir that MegaLogViewer.jar is in.
I am using the native version?
I will try uninstalling and reinstalling.
You won't need to uninstall the existing one, download the Linux version and extract it to any folder, then use the .sh script to run it.
I will have to look at setting the OS X version to use large memory by default on a future version.
